spicer 70 question
Ironhead
h-town
ok its not a srt-10 but it is a magnum ten ,,
i have a 3/4 ton with a spicer 70 in it ,,,i was thinking the ujoints might be bad cause when i go in reverse i fell a small hesitaition sort of ,feels like a real bad ujoint were it like skips a bit ,,,but i replaced the ujoints even though after removal they looked real good ,,
i also feel it a bit if im driving real slow and turn the wheel ,,it has a limited slip diff in it,,, is this what im feeling or does it sound like a rear axel bearing going bad ,,,driving straight and 70 plus miles per hour i dont feel anything:dontknow:
you need to pull the cover, you may have a tooth missing on the ring gear, or too much play between the pinion and ring due to bad bearings
ouch ,,i just drove 80 miles an hour from lake livingston to houston ,,going straight i dont hear anything ,,,backing up and turning well a bit i feel a slight hesitation ,,,but i did get it well used ,,:),,i need to finda good used entire axel ,,ready to go,,i was thinking it was the bearings ,but i think i can bag a good used on here in town at a pick a part ,,,,lol no stink not your kind of pick a part rest stops
i would pull the cover jsut to check, it may be an easy fix good sir, the 70 series isnt too bad to deal with
It also might just be the limited slip clutch pack. Did you say it was limited slip?? Anyhow, not to bad to repair. Think it would be less than a pick a part and you may end up the same or worse with that.
true true
i bet you just so happen to sell some parts too huh lol,,,i have 3.55 in it ,,,if you get time look and see what a new carrier with one step up in gear say 3.92 or sometin ;) ,,,maybe 4.10 :dontknow:
hang on im getting my book out ,,,good thing there is pictures cause you know i cant read
Stinker said:
I can bud, I can even hook you up with the fella that may be albe to help you our verbally if needed sir
is he going to call me names lol:pj/k...i think i may pull cover off on monday ,,,damn i just remember the shiming prob i had with the big ten ,,,,i hope a spicer is easier to deal with !
