Anyone used one?
The Cam Tuner is a plug-and-play solution that compensates for the installation of aggressive cams in Dodge Hemi, SRT-10 and Viper applications. Aggressive cams result in a fuel mixture that is too rich at light load. The Cam Tuner features a single internal adjustment that can be used to fine tune for a wide range of cam profiles.
[FONT=Helvetica, Geneva, Arial, SunSans-Regular, sans-serif]The Cam Tuner is easy for an end user to install. It works along with the stock PCM to adjust the fuel mixture at light load without changing the mixture at high loads. When set correctly, the Cam Tuner restores the original high fuel economy, low emissions and quick throttle response of the stock engine. more[/FONT]
http://www.splitsec.com/products/plugplay.htm
http://www.splitsec.com/splitsecond.htm
http://www.splitsec.com/products/instpdfs/CamTunerInstr.pdf
