mjpmattox said:
Hey guys new to the forum, and am wondering if anyone has had problems with thier stock brakes squeaking on a RC? No matter clean dirty and only 7300 miles is this normal for our trucks? Any advice would be helpful....
after much research & on advice from a member "shade", i decided to give the following pads a try:
for 2005-2006 Model: ram srt-10
Centric Posi-Quiet Extended Wear pads offer a stable friction level across a wide temperature range. Low dust, long pad & rotor life, low noise, w/OE designed shims to reduce pad vibration and squeal. Not a track pad.
63-106-1085 Fronts-$70
63-106-0702 Rears-$40
they can be gotten from:
David Zeckhausen
Owner, Zeckhausen Racing
(973)761-5054
www.zeckhausen.com
these pads eliminated the brake squeak & greatly reduced the brake dust with no difference in braking quality...... i also followed his brake bedding procedure with good results:
http://www.zeckhausen.com/bedding_in_brakes.htm
the only issue had was on installing the front pads, they required a little filing to fit properly (easy to do), i've attached a pic showing where i had to file....... this is the same issue that guys who bought the autozone #1085's had...... these pads are twice the cost of what the autozone pads are & less than the ebc pads, but completely solve both issues we all have dealt with.... David Zeckhausen is awesome to deal with too !!!! you won't be disappointed !
after mentioning the issue with filiing down the front brake pads to get them to fit properly, dave replied with this:
"Randall,
I raised this issue with the president of Centric Parts. He had his guys pull a set of pads off the shelf and test fit them to a set of SRT-10 calipers. They've figured out what needs to be changed and have pulled all their inventory off the shelf and are modifying the backing plates. These should be back on the shelf and fixed by Monday. Future backing plates will be manufactured correctly.
Now, someone needs to get hold of Autozone and see if they'll fix their pads too. ;-)
Thanks for the feedback. It was very useful.
Dave"
what a guy !!! i'd buy parts from anyone with this kind of service !!!
