TurboFreak
The FM/AM part of the radio has not worked since I bought the truck so I have been listening to CD's. Well I decided to fix the problem. I removed the bezel and radio and found that the antenna was not hooked up. The previous owner must have had an aftermarket stereo and the antenna was cut and speaker wires were run through the dash. I could not hook up the antenna as part of the tip had been cut off. I took it to a stereo shop and they spliced a new antenna in but it was not a 100% fit. I need to go to the dealer and buy one I guess as they did not have the correct one. But at least it work for now.
Also, I noticed that the back of the stock stereo has plugs for two connectors to go into. The bigger one is there but I do not have the second one. I was told it could be the one for the stock amp. Which could be why the sub-woofer also does not work.
Is there supposed to be two connectors plugged into the back of the stereo plus the antenna or just the one bigger connector and antenna? If only one connector is used what else could be causing my woofer not to work?
