VENOMOUS1 RACING
Quick racing how-to from #Venomous1Racing
Since it's that time of year Post vids, have fun and break records!
Posting here to help avoid typing it over and over in PMs and texts. Lol
Hope it helps y'all
Scott
Ok let's start.
Bring a helmet! Wear your seat belt! Now we have safety out of the way, you'll want absolutely nothing in your bed! Clean! You don't wanna drop a screw, nail, cd, ice chest or a penny on the precious 1320 (1/4 mile)!
Lower rear air pressure to 20, raise fronts to 45! Normal should be 32-34 psi.
If possible, go around water box, into track, then back into water box. This way your front tires aren't dripping water for you to spin on off the line If you can't, no biggie, go through water box, then stop with rear tires past water box. (Track attendant may guide you to where they'd like to to clean off tires/SMALL burnout. No smoke show!!!!!! Just clean off the water from water box. Smoke shows are for slicks to get rubber sticky. Street tires will get slipperier!! Just clean off and slowly approach the start line/tree. As you slowly approach tree/start line note the very top lights of tree. These tell you that you are at starting line. The first bulb is pre-stage. Light that bulb, wait for opponent, prepare yourself, and be ready. Once opponent lights his pre-stage bulb. Go forward very slightly again and you'll light the second light, the Staged light. Meaning you are ready for tree to count down and race to start. If you have no opponent do just as above without waiting for their staging lights. "Cutting a good light" also known as when you leave once tree is green to start, has NO effect on your time!!! Only matters if you are bracket racing, not for your personal best time. In other words, if tree counts down, and your not quite ready, take a second (1-2 seconds literally!!) then mash the gas! It won't affect your time as timer doesn't start till you move, not when light turns green
Clutch working-
You don't want to just drop the clutch at 2500 or whatever rpm till you have slicks! You'll just blow street tires off! I'd personally start at around 3000rpm and slip the clutch like you're taking off from a stop light fast, but don't wanna spin. Gradually release clutch, but obviously not too much. Same with 1-2 shift but a little faster ckutch release. Not a dump!! 2-3 and 3-4 shift you can power shift and dump clutch between gears. The main thing is getting through 1st and 2nd gears with little wheelspin, yet also never bogging engine. You want to leave the line as high as an rpm as your tires allow. Clutch and gas pedal being feathered for initial launch till full grip of tires, then full throttle. Make small decreases in tire pressure in rear and find the sweet spot for that particular tire compound.
If you get wheelhop, let out of gas and reapply gas. Next round let more air out of rear tires. Don't be afraid to use 15lbs.
Have fun, be safe, and practice makes perfect and everything you learn launching and shifting at the track will improve your street skills drastically
Enjoy and take lotsa vids
#Venomous1Racing
Hope it helps y'all
Scott
Ok let's start.
Clutch working-
#Venomous1Racing
