Stinker ,oil lines ?
VIPR PWR
Well-Known Member
FL
Stinker what are the specs , size of hoses , an fittings on your oil lines...would a bigger size hose help improve the oil flow..... Your input please ---Thanks :rock:
AN fittings sizes for the steel braided oil lines
the lines are a 10 an hose, the ends are crimped for a lifetime warranty, and they come with 4 o ring pump fittings for the correct fit into the pump and the block.
the hose is a ptfe hose, a teflon inner bore design, with a smooth bore design, and convoluted design wrapped outside, and a stainless steel braid on top of that for abrasain resistance.Impervious to brake fluid, lubricants, fuels and alchohols, will not degrade or allow vapour penetration.The smooth bore inside increases flow, and the convoluted outside gives amazing flexibility.
temp range -70 degree C to 260 degree C
material
anti-static ptfe smoothbore, stainless steel braid
specs
bore size 15.88 mm, braid od 20.8, working psi 955,burst psi 3820,weight .2352 lb, min bend radius 45degree.
since it kinda has something to do with my lines that i'm about to dig into...
there ain't no way you typed all that...don't you just love cut and paste...
makes all the words spelled right with correct punctuation and all!!!!
love you!
lol, after reading that description, it brings to memory that lawyer in My Cousin Vinny asking, 'does that come turbocharged?'
