STINKERS QUAD CAB DROP KIT!!!!
WA 2 FST said:
Is the stock perch/plate welded? If so, it seems like it would have to be cut off to be removed.
Could I install it, get it all bolted/torqued down properly, and then take it to a welding/muffler shop to do the welding?
I agree with the others that feel the truck is really high stock, but I'm used to a lowered (but not slammed) truck.
yes, hold on let me see if I can post a pic of the instructions for you:D
it may take me a minute or two, so hold tight
here is some of the instructions, I had pics of the destruction the other style can do , but they must be on the other computer
Now also it needs to be welded very well, a regular wire welder at a muffler shop want do;) someone that does welding for a living, and knows penetration is the person you need to use bo
shouldnt have a prob in tx:) check a local commercial truck garage, usually they have someone that is top notch as a welder, sometimes a muffler shop does, but most of the time they have wire welders, an they may not get enough penetration into the weld;)
WA 2 FST said:
The truck looks outstanding. I have the same type of rake on my L, and I love it. The front of your truck at 7" off the ground is 2" higher than what I'm used to in my "other" truck, so that won't be a problem for me.
But on Stinker's website, there is an installation comment about the rear needing some "welding, that should be done by a professional." What is that about?
I've installed a number of lowering kits on cars, and done two trucks. What is involved in this install? I can't weld, nor do I have the tools, and I'm certainly not going to tackle my first welding job on something this important.
A simiple install explanation would be helpful.
Thanks!
Also, where did you get the black wheels? Are they OEM Nighrunner wheels? I think they would look excellent on silver.
Thanks!
The install is easy as they say. Just bot it down real tight and make your way to a welder.
The wheels are powdercoated. I am not a chrome person :D
If you have any other questions let us know. It was well worth the price, and like it was said before very family friendly!
