Stock CAM
I have a stock cam for sale. Maybe of use if you can have someone spec it out.
its from my 04 manual but I believe they are the same.
DESCRIPTION
SPECIFICATION
Metric Standard
Lift 8.13 mm 0.320 in.
Journal
Diameter 1-6
53.09-53.11
mm
2.090-2.091 in.
Boar Diameter
No.1-6
53.16-53.19
mm
2.093-2.094 in.
Diametrical
Clearance
0.051-0.102
mm
0.002-0.004 in.
Max. Allowable 0.127 mm 0.005 in.
End Play 0.127-0.381
mm
0.005-0.015 in.
Valve
Timing-
Exhaust Valve
Closes (ATC) 36.5°
Opens (BBC) 88.5°
Duration 305.0°
Valve
Timing-Intake
Valve
Closes (BTDC) 86.5°
Opens 23.5°
Duration 297.0°
Valve Overlap 60.0
seems like someone figured with the cam lift, 1.7:1 rockers our engines run a .520ish total lift
