Nothing like having made every mistake...those scars make for good perspective!
Prof said:We tried to put a billet oil filter on my truck (Boomer) and it caused the flapping noise...it is a back-flow valve...and the noise could not be stopped. We dropped the billet filter...
For the cost of an oil filter i would try that first.BDR SRT-10 said:Soooo, should I lean more towards the oil filter making the new noise and switch back to the original Mopar one, or is it quite possible the belt and/or loose pulley bolts??? Like I said, I've never heard this noise until now, after I've used the new 'Viper' oil filter... And the only reason I switched was b/c of the higher flow capabilities it's said to have over the original Mopar...
Also, what do you guys mean when you say back flow valve noise???
Muzzy said:It is the oil filter that makes the startup noise. It is resonance caused by oil system pressurizing. When the truck sits for a long time without being run, the oil slowly drains out of the system back into the pan (even with a anti-drain back valve in the filter). When you start the truck oil is being forced back through the system through the holes in the filter causing the noise. If the engine has run recently, it won't make the noise since the oil has not drained out of the system yet (or very little).
I have compared the Mopar filter to others and the main difference is the number of flow holes around the outside of the filter face. The Mopar one has more of them. This would allow more oil flow thus eliminating the resonance. This doesn't make it a better filter, just different.
It is pretty common knowledge in Mopar circles that the filters are rebranded by whomever Chrysler chooses to contract with to make them. They may not always come from the same vendor even though they will have the same part number. Could be the reason why some get the noise with the Mopar filter and some don't. It is annoying, but will not hurt anything.
-Muzzy
If you still have the noise with the regular filter,Check the belt and pulley bolt.Alberta-SRT said:Mopar filters still have the noise for me, Both the regular one and the Viper one. Next I will try the one Inludemeout mentioned. If that doesn't work a K&N will be my next option.
I have checked it, everything is fine. the noise is not the squeal of a belt, it is a resonating sound that does not change with engine rpm.JRSVIPR said:If you still have the noise with the regular filter,Check the belt and pulley bolt.
Prof said:put them in photobucket.com (free) and cut and paste the lowest address and insert it here.
BDR SRT-10 said:/\/\/\/\ By stating billet filter, is that a.k.a. new Viper filter?? Back flow valve? Is that in the new filter too??
I trust your advice, just wanna make sure I understand??
