Streetable HP?
At 10 psi I'm hitting 660 RWHP and 720 TRQ. I think I might drop it down to 7-8 psi.
bigike said:
DUDE......................Back Half that thing! :D
Not sure what a back half thing is. Well I have an idea but this is not in the offensive section. :D
i had a greddy profec in the vr4...i loved it...it was a few years back, so i'm sure they've upgraded, you can set the boost only when you were idling, but, say for instance, you were in the middle of a race (that's more than an 1/8 mile) you can adjust the boost higher, then press overboost and it would override to the new setting...
if 500 horses spins in 4th in the rain, anything more than that, and you'll still have to watch it...
its an easy fix, all you have to do is the two screw fix:rock:
take out the two screws that hold on your tag, remove the tag and put it on a dodge neon......problem solved:)
