First off our trucks come rich from the factoryas a detune, so as to save the vital componets ie, tranny's and clutch.
Second the flash takes away this, adds timing to lean out the fuel condition, thus more power, more efficiency.
Octane rating is how fast or slow the fuel burns, plus with the timing from the factory lower octane ratings will cause detonation, although on 05's this can be resolved with the knock sensor.
When you get the computer flashed, it adds timing and proccess the fuel delivery different from stock, to give the engine better performance. Therefore the advance timingto where if 87 , or in that area octane is used detonation will occurr.
With a flash it is best before you order your flash to tell them what octane rating you have in your area, with that you should not have to worry about detonation.
hope this helps
hope this helps
