My sub box has a small rattle or squeek. Does anyone know how to remove the sub woofer assembly. It will move up about an inch but won't come any further. Any help would be great.
It's held in by a bracket. There is a screw in each side holding it in. You might need a flashlight to see them since everything is black. Once the screws are out, it just takes a little jostling to work it out enough to unplug the wiring harness.
