kickinassrt-10
I have a JL 10" w3 dual 2ohm voice coil and I want to know how to wire it to run off the factory amp and the connectors for the factory sub....How would I wire the sub to put out the proper ohm and how would I connect to the factory amp....I had the sub now wired with one wire running neg on 1 voice coil and pos on the other....I then made an adapter that plugged into both green wires on the factory sub connector and into one positive on the sub and did the same with both black wires into the neg side....I powered on and it sounded like it was blown (i'm assuming since it was not wired to the proper ohm of the amp is way too weak to power this sub) any help:dontknow: :dontknow: :dontknow: :dontknow:
