For the Rumble Bee you can get a GSM supercharger kit but it uses aux injectors that add fuel thru the tb and that has been known to lean out the two back cylinders and blow the engine. Sharadon Performance (www.http://www.sharadon.com/.com) in MN was working on a derivative of that kit but with eight larger injectors instead.v10 fat said:hi guys going to super charge my srt 10 im going with the paxton. do yoy no were i can get a supercharger kit for my rumblee bee ????????
thanks
TurboFreak said:BTW, the Rumble Bee is not the same as the Yellow Fever. One has a Hemi engine and the other has a Viper engine. I am not sure by your post if you have a SRT-10 and a Rumble Bee or you have a yellow SRT-10 that you incorectly called Rumble Bee because its yellow. If its a SRT-10 and its yellow then its a Yellow Fever edition.
TurboFreak said:...... If you really want to have some power you can get the STS turbo from www.ElColasMotorSports.com that also comes with eight larger injectors and a 2 bar MAP sensor.
ViperTruck2933 said:Rumblebee...YellowFever..:dontknow:
It's all the same isn't it..![]()
You might want to go back and read it again.....Silverback said:I'm sorry, but anyone that buys a STS for their truck is a god damn fool, and any one that would recommend one is not far behind.
For the owners here and back on the NFFF that tried the STS, over 60% blew up their engines. One person lost 2 engines.
I'm going to assume that you have not had much experience with the STS on a Viper Truck since you recommended it. You might want to do a search on it here to see all the damage it has done.
TurboFreak said:You might want to go back and read it again.....
I do recommend it but for the "Rumble Bee" that has a 8 cylinder Hemi. It works tits on that engine. I would not recommend it for the SRT-10 unless you have deep pockets, lol. If you look at the part you quoted though you will see I wrote that it includes 8 larger injectors(if I was writing about the SRT-10 I would have wrote "10" larger injectors.
The part you quoted is not there any more so you can't read all of it as it was probably edited by a Moderator.:dontknow:
BTW, "you might want to a do a little research" sounds like those caveman commercials on TV.
Silverback said:I will just ignore the "Caveman" comment and let it drop unless you want this to continue.
Bone said:Are you saying Cavemen aren't smart?! And what, Forum Therapists are?!
