Supercharger Seeping Oil.
azpyroguy
Beyond the Sun....
I noticed when I changed out my oil temp sender unit there was a small amount of oil seepage at the bottom of my supercharger housing. It appears to be VERY little.
I checked the oil inlet, and drain to see if it was seeping from those points, as well as the main shaft areas, nothing clean and dry.
It appears to be seeping from the split in the housing at the bottom... so I am sending an email to Paxton to find out what they need to do about it.
Stinker said:
Fix
Remove sc'r install twin turbos:D
Probably inlet seal going bad, they should just replace it:dontknow:
hell he ran 13's stock....no need to get turbos and run the same time.....:D
DAMN RIGHT they're not leaking cuz I installed them!!!
Am pretty sure its the housing... does not appear to be spraying out or under pressure.. looks like maybe if oil sits the galley area overnight its seeping through the split in the case.
Emailed them to find out what they think..
I should have added :D :D at the end there Scot.
are there any thru bolts in that area of seep?
Maybe the SC has just heat cycled enough and the thru bolts require a retorq.
Just a stab at it
Just a stab at it
I will have to check that and see..
