RagunCajun
Little background, i have a viper spec t56 in my gen 2 Lightning. It's from a gen 2 viper, it has all viper hydraulics from the gen 2 viper car. Only thing to do with the SRT Ram is the B&M shifter. It has a spec 3+ 26 spline clutch. Truck makes 628/727. The problems happened even when the truck was making 100hp+ less. Ok, now on to my questions...
When shifting at WOT(doesnt matter if i lift or not), it's a little hard to get into gear. It will go half way then click into gear. It seems to always have done this. I've put about 9k miles on it since the install. Are viper spec t56's suppose to easier slide into gear?
I just put in Mobil 1 synthetic ATF as recommended on here through searching vtcoa. I also rebled the clutch line too. The clutch disengages fine and the truck drives fine.
A buddy recommended that i flush the fluid in the clutch master cylinder because it gets dirty and he said it causes issues. If the trans is indeed fine, i really dont know what to do. I doubt going to the new Venom shifter will help. It isnt as shifter issues, it sees it's either the trans or something else.
