Thanks Again John:M&H Tires
DevilDawg3097 said:
For all those wondering this tire should not change your gearing almost identical in height. If it don''t rain they will making smoke this weekend:burnout: :burnout: :rock:
where can i get tho's ? and what size rims ?
Go to M&H Tires website. On the order form type in VTCOA under discounts (or something like that) you will get a great price and excellent service. First Class Company.
Shhh...:secruity: ..the discount code is not public knowledge...
ok? but what the setup :D :D :D
looks like those new slicks stick out as much as the 390's do.....:dontknow:
is that a ground down stock caliper i see or wildwoods ?
did you inner tube those slicks ?
He does not have the stinker rear end...the Wilwoods work on the DTS/Stinker rear end not the oem set up.
FATJACK said:
Mine hooked HARD at 13psi cold, hooked good at 15psi cold. Be sure you have an accurate RACING air guage and it wouldn't hurt to have a small air compressor. Do you have cryoed spider gears?? If not I would not drop the pressure below about 20 psi.
No that comes this winter:D
They are eagle alloy 058 series:D 16x10 I got em at discount tire for about 128 each. You will have to drill the hole for the valve alittle for the intertube.
Yes Mopar they are tubed.
You WILL break the spiders on about the 2nd pass if the tires hook hard. PM NBT and see if he can get another set done, they are not very expensive (less than 200.00)
are you talkin' cryo'd gears ?? NBT the only place to get them ?
MUST be cryoed, no NBT is not the only place to get them, he has just been gracious enough to do the legwork for several of us.:rock: :rock:
DevilDawg3097 said:
Here are some pics of the M&H nostalgia 12x16 and the small tire I used to compare is a MT 275/40R17 which are for sale by the way:D
What are you wanting for the 17's?
