The aviation buttons "nos" how do u get them to light up?
SRT10VENOMOUS
1800HP Club. And climbing
Vancover BC Canada
Ok when im looking at these switches and installing them. there is a lil led in the center of the metal thorw switch i can see the filimint "i cant spell" in the end of the switch so there must be a way to get them to light up when activated... but there is only 3 prongs on the back Ground/ Power / normaly open switch/ when all are hooked up no light in the switch .. it works fine everything runs.. but is there a trick to get them to light up?? if so let me konw thanx...
Didnt VPRPWR have that setup? Might want to ask him if they ever lit up...
Dan, you got any info?
-Red
They should be the same as any other lighted switch. They will only light when the switches are turned on. Is it possible you got the power or ground on the wrong terminal? You should have a constant ground, switched 12v from the ignition, and the 3rd terminal is for the device you want to control.
ya thats what i have .. maybe the switches are toast not that its a big deal but it would be neat if they worked...
(-) Ground to chassis
(+) To 12v ignition Acc
(NO) 12v open when in off (to send 12v to device when on)
with just the - & + hooked up the leds should light with the switch on.
also the + that runs the light also runs the load on NO. Make sure you have enough amps to run the load also.
