The Sneaky Pete on the Paxton pipe is gone. (This is way cooler anyway)
Ram From Hell
Bremerton, WA
I always thought it was kinda dumb having the GenII logo on this kit.
A few of you might have read my post about what the spot on the Paxton charge pipe was really intended for. Well, I just had to do it.:rock:
This is the Vortech Mondo race bypass valve. It's just a wee bit bigger than the one included in the kit.:D
The hood just clears it.:p
Will it help performance? A bit. Does it look cool? Well, I think it's better than Pete's face on it.:)
Are you doing anyting special with the Sneaky Pete ??? I'd be interested in it if your not !!!:rock:
Uh, it's in a billion itty bitty pieces. It's part of the pipe, so it was necessary to grind it off.;) I guess I could send you a do-it-yourself bag.:p
It took a bit of machining, but I managed to do it all with hand tools. There are three bolt holes that need to be drilled and tapped, and a 1-7/8" hole cut in the center.
505'sFastestViper. said:
wow i really cant tell a difference between all 5 pictures
It's been fixed.;)
I really like it:rock: ,I am just going to grind off Pete,polish it and put fangs on there somehow.possibly a sticker:dontknow:
Before I knew what that spot was for, I was going to grind it down and use a standard Viper emblem. Should fit just fine.;)
Black1 said:
:eek: You used HAND TOOLS to grind that thing that flat/smooth!??!?! :dontknow: WOW! :eek: :rock: :congrats:
From what I have heard, Eric's really good with his hands.
Comes from years of self satisfaction.;) :D
It took a bit of patience.:D
One hand's really good, and the other has been catching up as I've gotten older.;)
I bet that blow off valve will sound really nice between shifts. Does it vent to the atmosphere or do you recycle the air back into the intake?
