Throttle body cleaning?
SANTEEN
Miami, Fl
What's the general thinking here? I pulled off my intake hose and there's a bunch of carbon. Normally, I would do a throttle body cleaning. But, I dont want to mess anything up. Thanks
I would remove the TB and clean it. It isn't going to hurt it. I would even strip off the TPS before using any cleaning solvents on it. Also, be careful not to get any cleaning solvents on the throttle shaft bearings. If there was a lot of carbon on the TB, you might also check the idle air motor, which is on the intake. That will affect idle if it starts to get gummed up.
-Muzzy
Does the TPS need to adjusted when it's put back on? And, will any throttle body cleaner work? Can the idle air motor be cleaned with the same cleaner?
