to be legal or not to be legal
tidnab
Simi Valley
Seems to me that you could rig a butterfly valve up and go through your cats or... NOT go through your cats... and you could flip the valve with a button... hence being street legal... :)... it's the only reason I haven't put on long tubes and mid pipes on either of my trucks...
check this remote butterfly valve out.... anyone used anything like this??
http://www.youtube.com/watch?v=LmAzo1F8Ck0&NR
I went with long tubes and high flow cats.
Fortunately in my State, if you keep the vehicle under 5,000 miles per year, you get a waiver for emissions.
Further, if you go over the 5,000 miles per year, in an OBDII vehicle (On-Board Diagnostics 2 - 1996 and up), all they do for the test is plug into the OBD port and check for trouble codes. No trouble codes = no problem ---> you pass.:)
Not positive, But i think Ferraritruck has something like that.
J.R.
Silent D said:
Cut 'em off and weld 'em back at inspection time.
Django
i'm more worried about the chp looking under and saying wtf ... maybe i'm just paranoid... but it's a big $$ ticket...
maybe high flows are the best bet.... you could do neat things with that butterfly valve though...
I got a ticket last summer on the I-10 out near Palm Springs...... The CHP pulled in behind me in a white Camaro ...He said I was doing 90..... He didn't say a fkn thing about my exhaust system, noise or anything like it.......
We talked for about 20 minutes.... He cut my speed down to 80 mph, aplogized for giving me a ticket and drove away......
SD
FerrariT has his manual cutouts, sound cool when opened up. I dont think he noticed an improvement in power though :dontknow:
Django
Silent D has the plan (my plan too). I may try just clamping in flow-thru's in place of the resonators, that are in front of the magna flow...then clamp the resonators back in after inspection.
yeah, that sounds like a pretty good plan I was just thinking you could bypass all 4 cats (with a butterfly valve) but still have the cats in place lol...guess it would be a lot of extra pipes under the truck though :( but it'd be legal :D
Get another mid pipe assembly, cut the cats off as close to them as possible,
Knock out the guts, go to Harbor Frieght, buy a tubing expander, make the hole big enough for a section of exaust pipe to fit through, insert pipe, weld pipe at both ends of cat, grind off excess material for factory look , then weld them in place. Looks stock:rock: , but will be straight thru. Will need some Sims though.
that sounds like a great idea except for one problem... i'd catch me my trucks and most likely the house on fire if you put me anywhere near a welder... i'd need a shop to do this for me... and as cool as DC performance is.. i doubt they'd do it although I can always ask I suppose :D ... hey maybe that sponsor down in vista.... that's not too far :D
Just tell the shop the Cat Mod is for an Off Road Application, He He, then have them installed at another muffler shop:D :D :D
