Dom426
:congrats: :congrats: :congrats: :congrats: :congrats: been tryin tosay that forever no one listensrottenronnie said:Using 110 octane on a 93 tune is similar to dialing timing back, and it will make less power.
505'sFastestViper. said::congrats: :congrats: :congrats: :congrats: :congrats: been tryin tosay that forever no one listens
The Itch said:I'm still reading but...:marchmellow: :marchmellow: :marchmellow:
Toluene can be used as an octane booster in gasoline fuels used in internal combustion engines. Toluene at 86% by volume fueled all the turbo Formula 1 teams in the 1980s, first pioneered by the Honda team. The remaining 14% was a "filler" of n-heptane, to reduce the octane to meet Formula 1 fuel restrictions. Toluene at 100% can be used as a fuel for both two-stroke and four-stroke engines; however, due to the density of the fuel and other factors, the fuel does not vaporize easily unless preheated to 70 degrees celsius (Honda accomplished this in their Formula 1 cars by routing the fuel lines through the muffler system to heat the fuel). Toluene also poses similar problems as alcohol fuels, as it eats through standard rubber fuel lines and has no lubricating properties as standard gasoline does, which can break down fuel pumps and cause upper cylinder bore wear.
