Wifey said:Heavier than stock is what is needed for Drag Racing. Untill someone comes up with one that is Heavier the 5400lb truck is Not going to launch.
We used a 75 lb flywheel in the big block Camero,and that was a launch!
Jerry
RedSrt007 said:I have over 30+ launches with the centerforce @ 5-6k RPM's with slicks & stock flywheel when testing and reviewing info for centerforce. My 60ft times were better them most with aftermarket flywheels.
My Opinion? Bang-for-buck, skip the fidenza and look into upgraded hydraulics (if you still have the stock ones), or spend the money for *better go-fast mods
A lightweight flywheel works better for a lighter vehicle in a supercross style racing more then a 5k lb truck in a 1/4 event
-Red
It depends on how much the plate costs, but it might be worth it. It is also supposed to fit the Vipers.Rice Eater said:they gave me back the flywheel and the center section is just wore all the way down to the bolt heads. think its worth orderring up a new center section and selling it? does it fit only our trucks or other cars too?
Around $500 for the clutch and pressure plate. JMB Justin sells them.HOT RAM said:How much are new Centerforce clutches?
:rock: ... more info coming.... Dan just installed my NEW flywheel...Wifey said:Heavier than stock is what is needed for Drag Racing. Untill someone comes up with one that is Heavier the 5400lb truck is Not going to launch.
Jerry
Quick,QuickSilver said::rock: ... more info coming.... Dan just installed my NEW flywheel...
(dcperformance parts "Chrome-Molly-Steel") it's lighter and stronger than stock.
The only problem is he also put in a new clutch (stock O.E.M.) at the same time
and I can't really tell you much until I can jump-on-her... 500/miles!
Quick
ViperTruck2933 said:Quick,
Why on earth would he put an OEM clutch back in? The Centerforce clutch and the new flywheel would have probably been the optimum set up.:dontknow:
That OEM clutch may not last the 500 mile break in with your power. Good luck with it but I suspect you'll be back in for another clutch job soon.![]()
HOT RAM said:Mine is acting weird,sorta "jerky".I may have the same problem.If so,I'll repair the Fidanza center section and sell it (hopefully).
That's what I've been hearing. The Viper tech that's installing it said it will be noisy at first before proper break-in.. I was just wondering how you did with this..HOT RAM said:Yes !!!!!!! I am not sure exact mileage,probably around 600.LOTS of around town stuff i.e., change gears a lot.Not 600 freeway miles !! Break-in is critical !!
:rofl: LMAO.. I bet before 499 you could cut the anticipation with a knife...Rice Eater said:i took it easy for 499 miles then I sprayed the bitch!
