I've found our (huge) stock cooler to be pretty adequate, even in Phoenix heat. Have you had temp issues with your's?
I agree completely that the converter builder needs to know about your engine so he can build you a converter properly. If you change your cam, you will likely change your torque peak which will affect your converter choice.
OSO said:Circle D is located off of 290 Ryan and would get my vote . Get a bigger trans cooler its not going to hurt any thing and since your at the track every other weekend your truck deserves itDecide if you are going to swap cams and plan ahead before you decide on a stall . Just my 2 cents lets make it 1 cent i haven't worked in over a year
Wouldn't hurt to flush the trans check the bands and see whats in the pan.
