Traction control
WILDMAN
Oneida Tenn.
Just got my traction control system from JMB today. I haven't gotten to install it yet but should get to it by Saturday. I hope it helps even a little bit. Right now I spin really really bad out of the hole. I'll give it a try when it's on and let everyone know how it works.
Wade
Get ya one of those new fangled water bags that ties down in the bed !!!Fill it up when you need it,empty it when you don't !!Water sits right over the axle,can't ask for any better location !!!:dontknow:
Wildman
I got my JMB traction system on last night. It took me about an hour, but I did clean the back side of the wheels and the calipers while the tires where off.
I took it out and did a couple of launches and could tell some difference. It didn't spin as bad in 1st and only a little in 2nd. It was spinning so bad I was shifting to 2nd practically before I started to move then would spin a little in 3rd. No 3rd gear rubber now. I know it helped some. I will know more when I can get it to the track. I hope this info. helps.
PS I don't want to add a water bag to the beg for traction due to the extra weight it will add.
Wade
Pointless as the extra weight will kill you on the big end.
When I ran with a full tank of gas versus 1/8 tank I lost atleast a .10-.15 in the 1/4, and my 60' times were no better.
WILDMAN
I don't want to add weight. I wasn't sure if it would help out of the hole or not, but I knew it would hurt at the finish line.
Wade
I get all kinds of hook up. my 1000lbs topper gives me plenty of traction. wears on the brakes though. i keep front pads in bulk.
Me too. Best times were with quarter tank as well.
patrick
