Viper83101 Full Access Member Joined Apr 18, 2014 Messages 640 Reaction score 0 Location Georgia Nov 5, 2014 #1 Does anyone know the torque spec on the drain and fill plug on the T-56 transmissions? VENM505
VPRPWRD VTCoA Ring Leader Supporting Member Joined Mar 28, 2012 Messages 10,836 Reaction score 12 Location PA Nov 5, 2014 #2 How about this? MANUAL TRANSMISSION - T56 TORQUE SPECIFICATIONS DESCRIPTION N·m Ft. Lbs. In. Lbs. Adapter Bolts 34 25 - Back-up Lamp Switch 34 25 - Dust Shield Bolts 11 - 95 Clutch Release Bearing 20 15 - Drain Plug 38 28 - Fill Plug 27 20 - Flywheel Bolts 74 55 - Guide Plate Bolts 22 16 - Inspection Plug 27 20 - Interlock Bolt 27 20 - *Reverse Idler Brkt. Bolts 24 18 - Reverse Lock-Out Bolt 18 13 - Shifter Assembly 20 15 - *Shift Detent Assembly 34 25 - Trans. Top Cover Bolts 20 15 - Trans. Crossmember Bolts 61 45 - Trans. Mount Bolts 41 30 - Trans. To Clutch Cover Bolts (3/8) 35 26 - Trans. To Eng. Bolts (7/16) 68 50 - Trans. To Oil Pan (5/16) 23 - 200 * Needs application of Loctite® 242
VPRPWRD VTCoA Ring Leader Supporting Member Joined Mar 28, 2012 Messages 10,836 Reaction score 12 Location PA Nov 5, 2014 #3 Every T56 torque spec you ever needed to know and some you will never need to know.
Viper83101 Full Access Member Joined Apr 18, 2014 Messages 640 Reaction score 0 Location Georgia Nov 5, 2014 #4 Awesome! Thanks alot Andy VENM505
10-1=9 Full Access Member Joined May 21, 2014 Messages 1,735 Reaction score 4 Location Allentown Pa. Nov 5, 2014 #5 Anything worth doing is worth overdoing
