First thing to do in my opinion is to disconnect the negative terminal of the battery for a few minutes reconnect and see if the code disappears and stays gone...
If the code (P1494-LEAK DETECTION PUMP SWITCH OR MECHANICAL FAULT - SRT10) reappears, it should be a warantee repair...
