Truck paint
VIPR PWR
Well-Known Member
FL
What type of paint and clearcoat are used on the trucks from the factory? Enamal,laquer, etc.. Need help to paint fadeing on front cow catcher (hahaha) and rear bumper cover...need a better name for that one --Danko chime in.:D
None of the above. Dodge is using Urethane Base/Clear Coat. Not something you really want to mess around with unless you have a respirator capable of filtering isocyanates. If you are trying to save monies best to do your own body work then take it to a local painter for final. For more info see your local yellow pages and look at Automotive Paint Suppliers. Don't visit on Monday's or Friday's....most are too busy getting products out to local painters to really spend time educating.
If you have fading only you can simply prep and recoat with clear. Fact is the front cowls take a beating. In many cases I'll simply repaint in a single stage paint for that area.
I was guessing that just doing the clearcoat would be sufficient in this case....what type of clear would be the best and safest and easiest to appy ??????
I believe that the rubber, plastic and non metal parts has a 'flex agent' additive added to the paint to avoid cracking. This additive shortens the overall life of the paint.
for as much money as we paid for these trucks, i wish dodge could have painted them with a little more quality. it is the worst paint i have ever tried taking care of and i was detailer in the past. my wife's saturn has better paint.
Tone....agree. One thing all manufactures have done well is get just enough material down to get marginal coverage.
Vipr pwr....any urethane clear will be fine. I'd go with the one your local auto paint supplier supports. Most likely its either Dupont or PPG. Many other Manufactures supply this type of paint. Yes, even Sherwin Williams. Regardless, I think you need to do some 'readin' before you jump into this. Do you have an HVLP gun? Do you know how to prep for paint? If you are not very good with HVLP you'll need to know how to wet sand up through final polish. You'll need a polisher along with materials to go from wet sand to polish. As for flex agent...in my experience its not needed. Obviously go by what your paint supplier recommends. Other min things you'll need.....wax/grease remover, tack cloths, respirator, strainers, gloves and of course reducers and then there is a min of a 5hp compressor with a quality water extractor. HVLP guns need high volume of air to properly atomize the material.
Now....your paint supplier CAN mix up what you need and load a bunch of aerosol cans however you'll need to diffidently know how to wet sand/polish. Cans just can't put it down very good. Asking him to do this will probably get some strange looks and he might refuse...guess all you can do is ask.
Personally, pull the front cowl and drop it off at a local painter. Tell him what you want and while he'll point out what its going to look like due to rock chips etc you can decide what you want. (he'll want to do the job right by applying color coat/clear coat) If your local paint shops won't help go see your local Earl Scheb. They will throw paint or clear on anything....
Sorry if I sound like I'm discouraging you but unless you plan on doing more painting (justify costs) I'd turn it over to professionals to handle. Again, I cant stress enough that this type of paint is not something you want to take lightly regarding safety...its nasty stuff. You thought your college days killed lots of brain cells?
Doing this yourself the right way will end up costing you close to double what a paint shop can do it....if you were to do this yourself with the intentions of getting a professional result.
