Trucks in the shop. Disappearing coolant
Discussion in 'General Discussion' started by MDA, Nov 15, 2012.
Car Parts
  1. MDA
    MDA Full Access Member
    66
    Aug 13, 2012
    Last month she was way low on coolant and tried to over heat. Took her to shop for a block test. Checked good. They could not find a leak anywhere. Now she is back in the shop for the same thing. Again no leaks. No coolant out the exhaust. None in the oil. Where is it going? Any ideas?
  2. ARRESTmeRed04
    ARRESTmeRed04 Active Member Supporting Member
    5,882
    2
    Nov 5, 2007
    central texas
    I'm guessing the pressure checked the entire cooling system? I've seen radiators leak only under pressure so the leak going down the road but not with the truck shut off
  3. MDA
    66
    Aug 13, 2012
    My bad. Pressure test was done as well.
  4. ARRESTmeRed04
    5,882
    2
    Nov 5, 2007
    central texas
    Tried just replacing the radiator cap?
  5. MDA
    66
    Aug 13, 2012
    Haven't tried but no signs of leaking.
  6. ARRESTmeRed04
    5,882
    2
    Nov 5, 2007
    central texas
    I'd start with a cap
  7. yellowfever#154
    yellowfever#154 Full Access Member
    3,258
    2
    Dec 14, 2007
    Lacombe, Alberta
    What are the pressure test results, that will basically explain everything.
  8. SlvrSnake
    SlvrSnake Full Access Member
    1,061
    Dec 6, 2007
    New Jersey
    If the cap is bad it may be boiling over and blowing out of the overflow causing you to be missing coolant. Is your overflow resevoir filled to the max. If there are no leaks it is really the only thing that makes any sense. The coolant has to go somewhere.
  9. Slitherbeast
    Slitherbeast Well-Known Member Supporting Member
    2,281
    34
    Sep 10, 2007
    Alberta
    The coolant could be going into the coolant overflow bottle but a crack it the hose or a bad cap may allow air to be sucked in instead of coolant during cooldown. leaving the rad low eventually .
  10. MDA
    66
    Aug 13, 2012
    Got the truck back today. They could not find a leak anywhere. No charge. I'm going to get a new cap and see how we'll that does.
