TSB OIL LINES
500snakz
Here
One quick question. Does anyone know if chrysler will replace the oil lines on the tsb when the truck is out of warranty?:dontknow:
Prof said:
I doubt it...go with stinkers steel braid!
Agree with prof.,Stinkers lines are the way to go,stockers are crimped very poorly-they will leak around the crimped end its only a matter of time...
I just had mine replaced under the TSB at 39,500ish. It's worth asking, sometimes they will do them as a "goodwill" measure. I was told that they won't do them again(my 2nd set), so I'll get Stinker's lines next time.
If they were replaced once before under warranty, then we can replace them under a parts warranty. And that "goodwill" warranty is only for the really good customers, I guess they like you todd. :D
I am kinda cute and fuzzy:p :p :p
I'll agree with fuzzy but the other is up for debate. :D
My local Dodge dealership just closed it's doors. I've got nowhere to take it even if they would warranty any work on the truck.:mad:
I'm going to straight arm you in the........shin:dontknow: for that.
You should get your nephew to come up and work on your truck pro bono.
What was the name of the dealership?
oh boy my favorite subject.:rock: :rock: :rock:
go with Stinkers. great peice of mind & i think it takes out some of the restriction of the oil flow to the engine
had one line burst on me:mad: :mad: :mad: that was a mess:thumpdown: :thumpdown: :thumpdown:
i have several threads on this one:rock: :congrats: :rock: :congrats:
looks like they use heater hose & the crimps are crap.:toilet: :toilet: :toilet:
& don't forget the possibile oil pump by pass valve update:rock: :rock: :rock:
Boyette Auto Mall in Roxboro, NC. They were a multi brand dealership. Sold Chrysler, Dodge, Jeep, Ford, Mercury, GMC & Pontiac. Maybe a few more. I serviced their shop doors and we had a good working relationship. Really sorry to see them close down. Not just for myself but for the whole town.
Oil pump by-pass valve update ?????????????
Thank's guys...I will try the dealer first to see what they can do. Plan ''B'' is stinkers. When I had the master/slave clutch and flywheel replaced, it was out of warranty, they paid for the parts and I paid for labor 800 bucks. Times are tight there and I might get the same deal, just so they can keep their boys working. My dealer is first class in the shop. They all know me by my first name and the parts guy has helped me out before on oem parts.(sirius, door panel plastic part, door seal tsb).
P.S. Allways tip the mechanic that does your work, it goes a long way and they WILL remember it.:rock:
yep. check the Exotic Engine thread. there is a sticky there about it
:rock: :burnout: :rock: :burnout: :rock: :burnout:
