seethrough
Member
Figured I would try to start a conversation that didn't involve all the drama and could maybe bring out some intelligent discussion. Anyway I have been studying up on tuning since it has always been that black magic part of the auto world that I wanted to understand more. A few books that I have are starting to shed some light on things but everyone's PCM acts a little differently so I am looking for answers on how the Viper PCM works. I don't have any immediate plans to make changes but would like to understand what is going on when the tuners that are out there are working their magic. So here goes - if you have an idea of how any of this works join in. Here are a couple of things that I am not sure about.
1. What inputs does the Viper PCM use to determine WOT? I am confident throttle position is one input that it looks at but does it look at other inputs like speed, engine load, MAP signal? And what is WOT when it comes to the throttle position? 70%, 80%, 100%?
2. Does the PCM go into open-loop when at WOT and ignore the O2 sensors for fuel trim adjustments and run solely on fuel tables?
3. Are the knock sensors limited to a certain frequency range of noise so that they can ignore common engine noise and only detect a knock? Will it matter if they are moved from the intake valley bosses to a different area of the intake valley?
4. Is the IAC opened during WOT periods to allow more air into the intake system?
5. Is the IAC used during deceleration?
