When I bought my truck the previous owner had the rear cats removed. In place of those cats the piping went from 2 1/2 to 2 inch then back to 2 1/2. (I think it was 2 inch.) It was definitely smaller. Anyway now that piping was recently taking out and replaced with all 2 1/2 inch piping. The problem I'm having is as soon as I give the truck some gas it almost instantly goes to 0 on the boost gauge. This causes the truck to bog down or hesitate. Then after a second or two the gauge shows more vacuum and the truck acts normal. So here is my theory and you guys tell me what you think. When I give the truck a little bit of gas it starts to try and build boost at the turbo. This causes the truck to fall on its face. I didn't have this issue before because the back pressure built just a little at the inlet of the smaller pipe. Now that pipe is gone so it tries to build the back pressure at the turbo. Remember this is a rear mounted turbo so it works a little different the a normal turbo. I have this problem at highway speeds also. So what do you guys think?
Smoke
Smoke
