heat drives the turbine wheel. the smaller the chamber, or in this case manifold the faster the turbine will spool. the down pipe needs to be big to allow the heat to continue its travel without restriction. if there is restriction then there is back pressure. then returning the excess heat into the chamber. so maybe not the tune but more of an understanding of thermodynamics will allow a more efficient set up. Downstream of the turbine you want the least backpressure possible but the heat is what is driving the turbine so that is why wrapping the pipes are beneficial because you are keeping the heat in which in turn keeps velocity up. so pipe size is crucial because too big no pressure and too small too much pressure.
Very interesting. Thanks!
