Ok here's th supposed problem plain and simple with my twins .
In the first three gears, you see about 7 psi,but where you can really se it is in fourth,.
cruise in fourth and hit it, the rpms climb, goes to 10 psi then slowly bleeds off to 7psi.
other than that smooth running. easily braking traction. Boost comes on hard and quick.In the first three, it rev's so quick you dont notice the drop, plus you are focused on shifting. but in fourth you have time to watch the problem.
intercooler was pressurized and ok now. going out now to do some checkkingon vacuum lines.
any suggestions good or bad while gone will be appreciated.
oh and do ahve a boost controller set for 10psi with 7 psi springs installed.
