Burkerice07
I have here a Unique shift light i bought for $150.
What makes it special is you dont need An RPM gauge for it to function, On the back there is a dial that you adjust anywhere between 1000 and 15,000 RPM.
It is a simple 3 wire setup, 1 Hot, 1 Ground, and the green wire hooks either to a distributor hot wire, or an Ignition coil hot wire. and works with 4, 6, or 8 cylinder engines. I bought it for the Truck because i like the Big Size, But i cant get it to work on the V-10
It would be great for ANY other vehicle, Even an Automatic, just to know your RPMs if you dont have a Tach
I still have the Yellow Rubber cover, and everything, this unit is only about 1 month old. Im looking for $60 So i can buy a Raptor shift light like i should have in the first place. Any Takers???
