Upgraded Clutch??
10boom
Washington State
For all guys that have the upgraded clutches, Centerforce....etc.., is that something you did yourselves or did you get it done somewhere? How much is the Centerforce upgrade? Thanks
Depending on how "mechanically inclined" you are, it is a 4-6 hour job. It makes the Job 100% easier with a lift then in the driveway :D
As for $$ , the centerforce Kit runs about 500-600 depending on where it is purchased. If you want the hydraulic kit, including the flywheel, it will run about 1k more.
For any information on the centerforce, check-out the review section...
Thanks
Red
Got my complete clutch upgrade with Roe Racing $1500. Dealer did the install for $400. Centerforce, Fidanza, Viper slave/master etc...
Boomer sells this also. This setup works awesome too!
You will need to safely get your truck high enough in the air to slide the trans out from under it, Maybe ever higher if you use a trans jack, so yes a lift is really the easiest way to go.
Bill.
