- Joined
- Jan 30, 2007
- Messages
- 5,966
- Reaction score
- 1
+ clutch...
+ master slave
+ master slave
FerrariTruck said:well on a stock motor you need the meth kit right away or else you will break the ringlands off the pistons.
The crank pin kit, Our crankshaft pulley/harmonic balancer is not keyed on our crank like conventional engines. The center bolt is all thats holding it together. when adding anymore load to serpentine belt it maybe cause the pulley to spin on the crank causing damage.
Its is easy to install and comes with instructions.
WWW.roeracing.com
Even though your motor is young, its still maynot hold up for a long time so plan to get a built motor
