Vec2 and Vec3 from Sean Roe
Dave T(BADVENM)
Danko's head
Heres a post from Sean on the Viper forum about the vec2 and vec3:
Hi Everyone,
Sorry I didn’t come on here earlier and address this topic. I really did intend to.
Here it is in a nutshell.
The VEC3 is a progression from a VEC2 in regard to the circuit board components and interface. The processor, drivers, etc are the current state of the art components. Does that make it any better than the VEC2? A little, in that the components are now more robust and it uses a USB cable to communicate (allowing for an additional set of inputs in the back). Is that a reason to change over from an earlier VEC2? No.
With the new box release, we also introduced new firmware and software versions. The firmware is the program the processor uses to operate and the software is the interface you use to write different fuel curves, timing curves, etc.
During the last twelve to sixteen months, we’ve been working on making the operating system and software better. To that end, here are the changes that have been made over firmware 5.108 and software version 3.5.0 (dataset 106).
- Intake Air Temperature input function. There’s a new page within the fuel table to offset the final injector output pulse as it leaves the box. You can leave the offset at 0, or scale the fuel up as the air is cooler and down as it gets hotter. It doesn’t take much of an adjustment. The stock PCM’s IAT input is not disabled to make the VEC’s work. They both work together. It makes no difference on the year of the vehicle. It’s just an offset to the final injector pulse time. If the pulse out was about to be 10ms and you have a hot day with a 2.5% decrease at 140 degree IAT, the output pulse will be 9.75ms instead. Simple as that.
- For the Gen 3 cars, we’ve added a function that eliminates the problems associated with the stock PCM’s holding closed loop operation for the first 1.5 seconds of full throttle. Closed loop is the operating condition where the PCM monitors the oxygen sensor voltage and alters the injector pulse in order to achieve a specific voltage / air to fuel ratio. It does this on the fly and instantly. If you have a 2003+ car, are cruising along and slam the throttle, the stock PCM will continue to monitor and a adjust the injector pulse to achieve the optimum (for emissions) 14.7:1 air / fuel ratio for 1.5 seconds. That’s not so great in a lot of different ways for a lot of different reasons. Suffice it to say “LEAN†at full throttle is bad for engine life. We put in a function that clamps that down and keeps it from adjusting the AFR on the 2003+ cars. Very beneficial for naturally aspirated and necessary for forced induction, unless you have an aftermarket flashed PCM where it’s been turned off (not too many people know about this problem).
- In the logging, we’ve added a horsepower and torque graphing function. Utilizing this function along with an air / fuel ratio sensor input allows you to do full tuning without having to go to a dyno. It won’t necessarily produce the exact same numbers as a dyno, but is just as useful for tuning. Any area where the ignition advance or air / fuel ratio is not optimum will show up as a lower power area. It’s pretty slick really.
Any other changes made in the firmware and software have been made as a matter of evolution. This is the best to date.
All VEC2’s can do the same thing as a VEC3. The only real difference is in the input configuration. A VEC3 has an Analog 4 input on both master and slave board, where a VEC2 does not (the VEC2 uses that port for serial cable communication). On the VEC3’s I use the new AN4 input for the IAT input.
Assuming you have a VEC2 (silver box, where a VEC3 is black), should you update or not? Here are the facts, pro’s and cons:
If you have a 1992-2002 car, the only benefit of significance is the IAT input function. Not all “need†this function. If it isn’t broke, don’t try to fix it. A stock Viper has a wide fluctuation in its AFR due to IAT’s, but most people never see it because they don’t start monitoring their AFR until after they’ve modified the engine.
There are some 2000-2002 cars with stock PCM’s that hit 100% injector duty cycle output, which can screw up an older firmware VEC2 (causes a miss at about 5,500 RPM in hot weather). Those would benefit from the firmware update, even if they didn’t use the IAT function.
If you have a 2003+, yes, you should update your VEC2 and wiring harness to the newest frimware / software. These cars have a bad program from the factory that turns the fuel up way too much when the air is hot. Just kills the power and fuel economy. Additionally, you’ll want to get the closed loop delay eliminated. Makes better throttle response and is better for your modified engine (will help keep it alive if you happen to punch full throttle at 4,500 RPM or so by allowing the AFR to come down to where it should, not go lean for 1.5 seconds).
The downside to the update is compatibility and wiring. The new software is version 3.6.11 and the dataset is S108. It’s not compatible with the older S106 version. If your VEC2 is updated, your box will not read the S106 cards any more. You’ll need to have the cards changed over and need new software if you have the S106 version. You’ll also need a set of IAT wires and or additional wires if yours is a Gen3. Is it the end of the world to do this, no, but it is a little time consuming if you’re on the end of the desk thinking about the 850+ VEC’s out there :)
So, if you’re thinking about doing it, let me know in advance of sending anything in. We don’t mind doing it and helping everyone out, but we may have to charge something for it since that will be a lot of work and time spent.
Hope I didn’t miss anything. If I did, I’ll try and pop back on soon.
Regards,
Sean
Sweet, so for me i should get the VEC3 because i have never owned a VEC. Also, the function where the program can act like a dyno. Is that
just as good as actually getting it dynoed? i know in Seans writeup that
it is sub par to the actual Dyno. but is it really that much worse than an
actual dyno? I'm just about ready to drop 1100 on a VEC3 and just
want to make sure that i'm investing my money wisely. :) :rock:
Sharpi
I have the VEC III...do not, I repeat, do not buy it on the basis of it replacing a dyno. I love the VEC III and have always thought it was the very best way to go if your are serious about having the best tuning capability available...but you also (as with a pcm flash) need an expert tuner.
The hp/tq readout is just not a valid reason to make the purchase. I recommend highly the VEC III but not because it can read hp and tq.
The flexibility, and the ability to re-tune and tune on the fly is the reason to purchase it.
I believe you can get a small price break if you purchase the VEC3 from Joe at Performance by Joe out of Saint Louis. He's a distributor for the VEC through Roe Racing.
so if i read this right , this is something that the average person can not do?
I guess what I am asking is can a dumb joe like myself get this program and use it without messing up the truck
You can hook your pc up to the system and tune it yourself...it's the old adage of make or buy? Would you take the time to learn to tune up your $13,000.00 Rolex even if you had all the tools? You could learn to do it and probably do it pretty well...on the other hand would you take your Rolex to a watch maker and have them clean it and pay $400 every two years to have it done? Now view your Viper v10 as a $19,000 Rolex (before any mods)...you will need to know much more about the V10 than you know about the VEC III to tune it well.
Yes you can do it...but why would you? Stingray learned to do his own tuning...ran super times. He works full time on GM vehicles...so it was avocation to him...
I am an average Joe like you. I turn my own wrenches on most bolt on jobs. But there is no way in heck I would try to do my own tuning with a VEC.
I am adding the VEC 2 in conjunction with my flashed PCM and cam/head porting. Joe Donovan will be doing all of the tuning on mine.;)
I partially agree...its just tough to box up your truck and ship it off to a expert tuner :D
Sooo, lets say your'e the average Joe that tunes their old hot rod, wrench on all your vehicles, bolt ons and modify your truck but then send it off to have it tuned ? Believe there is a little too much mystique at times when it comes to the Viper V10. If you take small safe steps in your tuning until you get the hang of it then everything should be just fine ;)
Guys, Sean will give you a program that will be safe to use. You will not have to create it from ground zero. You will have to only tweak it after that. However, for major upgrades or NOS, best to go with a tuner, or get a dyno done and send it to Sean for a tune. It is not overly difficult. It is complex and is very flexible. But if you take it a step at a time, the average Joe and even Mikey can tune with it.
You also have all of us on here to help with the tune. Post up a dyno with A/F ratio and we can go from there. even email the tune back and forth.
It is actually fun to program with it.
Just my 2 cents and most will not agree or like it:D
The vec is an awesome piece of equipment, but with that said, unless you are
a very capable person with wiring and soldering, please dont attempt this.
You have to cut the injector harness, 2 wires to every injector, very easy to get lost.
but the wiring MUST be spot on and soldered perfectly or down the road you will have problems.
the Vec is easy to tune with, would I ever suggest someone try it on there own?
NO, I dont want the responsibility in my head of sayin yes you are capable, then them torchin the engine.
Personally the dyno and send them a copy is ok, but not the best, it really needs to be tuned by a "viper" tuner while on the dyno.Just my opinion on that.
but my main point is
unless you are a tuner, have done some tuning, you may be able to do it yourself.
But if you havent, are you willing to bet a very expensive engine on your tuning skills , or the advice from people that you have never met?
Me? No, I want touch it, I jsut leave it to the guys that tune vipers daily, my opinion its the safest way.
I guess Sean isn't a qualified viper tuner??:dontknow:
Sean takes the results (dyno in house at Roe or from other dyno) and tunes from the graph. He gets great results. As long as the dyno is setup correctly, I see no reason he can't tune from it.
BTW, here's my VEC3 mounted inside the front panel today.
:withstupid: :withstupid: :withstupid:
-the stupid part :p
No, now , wasnt saying he wasnt a good tuner, he is a great tuner, but also tunes very very safe,
I Personally in my opinion think its better to have a viper tuner , tune the program while its on the dyno, at that time , and for those conditions.
I had Sean send a card from a dyno for Joannes truck in the begining, after his tune it made 450 or so to the ground,
After taking it to a tuner and tuning it on the dyno it jumped to 478hp.
Sean is a great tuner, but also a very smart tuner, he will tune, or send you a tune that will be incredibly safe for ALL conditions.
Just as the case with prof's truck, making 650hp or so, He may be able to take it to someone inthe area and get an aggressive tune that is still safe and get a few more ponies.
And by the way, I have the utmost respect for Sean, they are all killer guys, and super nice.
Stinker said:
Just as the case with prof's truck, making 650hp (sic) or so, He may be able to take it to someone in the area and get an aggressive tune that is still safe and get a few more ponies.
Planning on talking to Stingray about a tune for the Nats...then back to my street quick Sean Roe tune as soon as I get home! I'm determined to get under 14!
So that explains why all my A/F logs showed the engine going lean when I would first go to WOT! That always bothered me why I couldn't tune that out. For that and the IAT function I would buy a VEC3.
Don't give me too much credit :eek: I did what Bone mentioned. I used a program from Roe to begin tuning with (one of the sample files that came with the VEC2 software). It was very lean but the timing was good, so I only had to adjust the A/F.
DRamSrt10 said:
how much does vec3 cost?? just wondering
Call Dave at Roe Racing...(904) 529-1219...he can quote you exactly...mine was one of the first VEC III's and I never understood Sean's pricing to me...he was testing on my truck so I think he played with the pricing...expect to spend at least a grand.
$1,100.00
If you have a Vec2 already you can get it upgrade for much less :D
This feature was unexpected for me and discovered it when I double checked my tune with the VEC3 :D I used to throw loads of fuel in at the lower RPMS to bring the A/F ratio down at the beginning of the transition..... Now tuning is a breeze :rock:
EDIT: Shit you guys post fast. :vroam:
Say i buy a VEC but don't know anyone in my area that tunes vipers. Can
Sean send me a pack of pre programmed smart cards that i can use on my
truck? or are the sample files listed really not to hard to mess with as long
as you know what your doing. And, to be honest. I have yet to hear of a
speed shop im my area that can tune a viper engine. I've talked to everyone
i know that has an idea with cars. The closest i get to a possible tuner is a
old guy that tunes classic Mopars for a living. what the hell should i do?
Sharpi
