any of you know where to connect a wide band so that i can do some a/f loging with the vec3? i have the pin outs for the vec3 but dont really explain to well.
I contacted Mike at Roe, and he is having me connect at the Analog #1 IN. That is Pin 10 on the master connector. I should have mine up and logging by the end of the weekend as I still have to pull the wire from the cab to the VEC harness.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
