Floor said:
I think the hardware (tank, evaporator(s), injectors etc) can be used for other gasses aswell. System basicly consists of a VSI system (vapour sequential injection) with integrated motormanagement system (master/slave on the std system), communication with laptop possible through CAN, high flow (14 gram/s) evaporator(s) with overpressure protection and 'Keihin' injectors. more info on
http://www.prins.eu/en/index.html.
But in the end it replaces the petrol fuel. If you want to use it for CO2 or meth the software should be completely different:dontknow: Maybe it's better to contact these guys and see what they say on this.
Now that's my problem with those guys : i calculated it myself : try to follow :
14 gr/sec x 3600 sec = 50,4 kg/hour.
So let's say you drive 200 km/hour ,you can evaporate 50,4:2 = 25,2 kg LPG per 100 km .
LPG is 20 % less energetic then petrol , so it's equivalent to 25.2 :1,2 =
21 kg petrol/ 100 km .
That's the consumption running at idle
So i prove LPG is not performance , not even with 2 evaporators ( 14 gr/sec)as mine.....
most time i can get 5000 revs... no more .
Be carefull for your engine : as my LPG specialist admitted after my calculations
is the fact that everytime you feel the shortness of LPG ( no more extra power ) you actually lean out the engine ...so sure not gonne drive constant at the limit ! or BOEM :star:
Then i also proved that the Keihin injectors are to small ( believe yellow ones are the greatest with 93 cc/injection ) .You should need 2 of those parallel per cilinder....
Now i think we must admit that those LPG installations are designed for smaller engines ( up to 300 -400 HP ) and for bigger ones as ours there's simply nothing availeble right now at the market.
That's evident that with my Roe i can forget LPG ....
Sorry.
But if you take as rule of tumb that a engine consumes the double for his last , say 25 % , HP , on LPG you run "safe" under 4500 revs... above you run lean which is dangerous !
