Water/Meth Injection: Final Phase
TNVIPER said:
I will try to get under and get you some pictures tomorrow..
Ok this is the information I'm looking for.
I know that I must attach a power and ground from the MSD to the pump no more than 12" away. What color wire do I connect the power (red wire from the MSD) to the stock fuel pump and what color wire do I connect the negative (black wire from the MSD) to the stock fuel pump? Next question is I need the location and color of the wire from the "Original Fuel Pump Relay" to connect to the (85) on the MSD relay?
I will have to get under the truck to remember what we did...........and the MSD does not need to be 12" from the pump...we read it the same way the first 5 times we read the instructions.."The long power leads of the MSD must be routed to within a foot of the fuel pump"....the leads, not the MSD..;) ......I mounted the MSD in the battery tray on the driver's side (my battery is rear mounted)...easy to get to the adjustment screw..
Thanks I appreciate all of your help.
Alex
Hey Alex....I cant get my, uhhh, pectal muscles under the truck to look at the connections...I will be putting the truck on the rack for other work the first chance i get and the weather cooperates..will let you know..
