Water pump, oil pump and PU, head bolts, stock injectors
faslane505
Houston
like the title says,
need a water pump, oil pump and pickup tube, set of head bolts.
possibly a set of stock injectors
thanks guys
head bolts oem? I prob got, oil pickup I got one thats bent, but they arent much new maybe $25?
let me know if its the oem head bolts and will scrounge up a few , I should have some laying around, oil pump and water pump not at this time tho
oem head bolts should work fine sir, yessir the oil pump is part of the timing cover, oem cover from dodge is about $1000 or you can send yours to arrow and exhange it for an upgraded one for around $600?
Oem balancer? I need to check on that, I may have one around, not sure on that buddy
check and let me know all the stuff you have and a price good sir. thanks TOny
We have everything in stock if you need. Inspect your timing cover and make sure it doesn't have any gouges or lines in it.
I have a set of stock injectors I took off last week. Let me know if you still need them.
