- Joined
- May 18, 2006
- Messages
- 35,137
- Reaction score
- 13,097
nycstev said:I agree . Fatigue failure. This guy is telling me its detonation and I don't buy that explanation. If you had that much detonation in all 8 cylinders you would be noticibly down on power. This Chally had only 700 miles on it! Obviously it didn't have time to reach fatigue failure in a conventional sense . I think it was WAY WAY over boosted so it just blew up.
This is the same person who is telling me my pistons failed from detonation.
I find it hard to buy. My AFRS were right on and the engine ran smooth as glass and pulled very strong with no signs of detonation.
The factory engines are steup to last many miles (tight clearences) a race engine needs much more clearence on most all of the components due to the heat, block/crank flex ect. Pistons/ rings need more, cranks need more also as do the side clearence of the rods. Full floating wrist pins are a must also.
There has to be enough clearance for things to expand and move around without binding or siezing. Example :in a Harley the piston clearance is/ was .001 , in the hot rod engines Yettie uses Venolia Forged pistons at .006
S&S uses (made by) TRW( or how ever they are now) pistons at .002 for the street. Parts must be adjusted for the application .........period.
