What does this mean???
VIPR PWR
Well-Known Member
FL
I get this when I try to open certain threads :dontknow:
Fatal error: Allowed memory size of 67108864 bytes exhausted (tried to allocate 27735 bytes) in /home/redcbr00/public_html/forums/showthread.php on line 1275
In your cPanel look for the PHP Config icon. In there set your php mode to PHP5 (Single php.ini), then save and install the default/master php.ini.
Then go to your public_html folder and find your php.ini. If you do not have a php.ini, you will instead have a php.ini.default... rename it to php.ini, then open it with the code editor and increase the "memory_limit" to more than 64M. Save and try your plugin again.
It looks like you have too many plugins running on your internet browser. You need to download a program like CCleaner and uninstall all unneeded add-ons. They are using up too much of your allocated cache of 64mb
:congrats::congrats::congrats:
wow someone knows there sh!t
This is easier then it looks but if you follow the steps closely it shouldnt take but 2 minutes. If you have any questions, let me know.
Step 1- Login into your cPanel.
Step 2- Under the Software/Services category, click on the PHP Config icon.
Step 3- In this screen, there is a section called “Install Default php.ini”. Under that section, please check mark the "IonCube" and the "SourceGuardian" check boxes (Many commercial php scripts need these turned on – if you think your script may not require the IonCube or SourceGuardian packages, it is okay to not check mark the boxes – but it will not hurt anything to check mark both boxes.).
Step 4- Under the same section, click the "INSTALL PHP.INI MASTER FILE" button.
Step 5- You have just successfully installed the "php.ini.default" file . But the next step is to rename it from "php.ini.default" to just "php.ini" to make it active. You can do the Rename in the File Manager screens. Under the Files category in your cPanel, please click on the File Manager icon.
Step 6- When you click on the File Manager icon, you should get a popup dialog titled "File Manager Directory Selection". (If you do not see the popup dialog, then you need to click on the link at the bottom of your cPanel called "reset all interface settings" – and then Refresh your cPanel and click on the File Manager icon again.) In the popup dialog screen, click the "Web Root (public_html/www)" and the "Show Hidden Files (dotfiles)." choices. Finally please click the "Go" button.
Step 7- If you already have a "php.ini", I would recommend that you Rename the file to "php.iniOld" in case you need ever need it.
Step 8- Find the file that you just installed called "php.ini.default", Right-Click the file and choose the Rename option.
Step 9- A new popup dialog called Rename should appear. Please start pressing your Backspace on your keyboard and you will start to see the letters disappear. Keep removing the letters until you see only "php.ini", and then click the Rename File button.
Step 10- Your php.ini file is now active and fully functional !! Additionally, some users need to make adjustments to this file. To edit the file, you just Righ-Click the php.ini file and choose the Edit option, and then change the value like these examples show:
a. To increase your memory for your php pages: memory_limit = 2M —> memory_limit = 100M
or
b. To turn on your Register Globals: register_globals = Off —> register_globals = On (We don’t recommend that you change this flag unless you know what you are doing.)
or
c. To increase the maximum file size for uploading (there are two flags that you have to change):
post_max_size = 2M —> post_max_size = 100M
upload_max_filesize = 2M —> upload_max_filesize = 100M
d. To turn on PDO, add this line of code to your php.ini file:
extension=pdo_mysql.so
extension=pdo.so
extension=pdo_sqlite.so
extension=sqlite.so
Step 11- Important: The php.ini file is generally directory specific. If you have "PHP5 (Single php.ini)" or "PHP5 (FastCGI)" selected in your Php Config screen, then you should not need to do anything else. If you do NOT have either of those selected, then you may need to copy the php.ini file into all of the subfolders inside your public_html directory. This may be dozens and dozens of subfolders that you have to copy the file into. Also, sometimes it can take between 15-30 minutes before the system recognizes the php.ini file or any changes that you have made in the file.
