What is the little bottle with aftermarket CAI in the intake bay?
kickinassrt-10
Miami, Fl
I see some of you have a small bottle in the intake area that connects to the valve cover port. What is this bottle and what does it do???
Crankcase breather catch can. It sends oil vapor to a can instead of into your motor. Reduces risk of detonation,
I just installed mine too. During the install I realized how much used oil ends up blowing back into the intake manifold and collecting just past the TB. That's terrible. After cleaning the intake manifold with the TB off I connected the catch can hoses and I surely will monitor how much crap accumulates in there. Justin has a great product that actually SHOULD hav been OEM from the factory.
How much do they run and is there one on each side of the engine? Where can I look to find one?
Thanks:burnout: :burnout: :burnout: :burnout:
Good 'ol Larry (TNVIPER) just gave up the 411 on Justin's site. All you would need is one since only one is ever used. Plus you're in luck because you have an '05 and I just found out the '05 and '06 models are easier to install these.
answer to your OEM question Antknee, EPA:mad: :mad: :mad:
