What is the widest rear rim we can use?
blackviper
Miami, FL
What is the widest rim / tire size I can run in the rear. I know some of you are running a 325 40 22 tires. I'd like to run 22x10 in the front and 22x12 in the rear. Will this combo rub on the leaf springs?
well first off you need to find a shop that has an offset machine..or buy one from jegs,or summit.....when i worked at a custom hot rod shop. we used to do airbags on mostly chevys a few dodge rams an other mini trucks..but a thing to rember is you can roll the inner fender lip to gain a 1/2 an inch or so...i dont see why you couldnt run a 12" wide rim in the back with a nice meaty tire...youll just have play around with it...we used to do it all the time when we would try to figuer out the rim size......its kinda tricky having to find the right size rim for a bagged an body droped truck lol...if none of this makes sence im sorry iv been up for 20 hours an just started drinking hahaha.....if all else fails buy a size you think will work an if it dosent..burn them off an get video of it then buy a diffrent size!
