I don't think the pulley should move. It's bolted to the harmonic balancer. Now your balancer might be on tight but the pulley bolts might be loose. You might need a mirror to look in there to see what size they are and if they need tightening.kpracing said:OK I checked it.
The size is 1 1/4 and it don’t feel loose but I cant torque it the engine just turns over:dontknow:
But I guess it is not loose, is it normal that you can see the pulley go from side to side or is it just mine
