What size injectors?
They sell 79lb high imp injectors that are good for up to 1400HP as well. How much HP are you planning on making?
For reference the 84#er's in the recent turbo truck were only at 85% duty on 50psi base fuel pressure making 1000+WHP.
Justin
Prof said:
Had 54's went to 48's.
Check spray patterns...the more atomization you can get the more efficient the burn...
already noticed that # was away in your sign......:confused: :dontknow: :D
Sean felt that the spray pattern in the 48's was much more efficient...
I am running my stock injectors.... Boomer just sold me a 10:1 FMU plate upgrade for mine... and I am running waaaaayyy fat on boost..... like sub 10.0 on the A/F gauge, and under no boost she bounces around 14.2-15.5, I have zero detonation...
I have the 10:1 FMU plates and two pills on the spring and can't use Gary's old tune cause it runs at 13.4 in third gear...
All this since the throttle body install...
