Prof said:Silverback is seldom wrong. I agree with him and NBT (big surprise) especially seeing your goal of low 600 rwhp...
If you want to go beyond the low 600's at some point, you would probably be better off with the Paxton...
The Roe will require VEC III and Meth Injection. Your CE will require the Centerforce Clutch, and the Viper Slave and Master Cyl mod. You will have to have Cal Tracs (or you will spin your life away in the 14's).
Your budget will cover the Roe approach with all the rest too.
Isnt it you that has the vecIII inside the cab. I think I read that it takes an extension for the wiring and it wa said that it is expensive. Do you know how much it is and do I get it from Roe?
