This ground wire started smoking and melted when I tried to start my truck the other day. I disconnected it and my truck runs great...it looks to be black and light green or blue......
hard to say what it is but since you removed the paxton i would check all the wiring that was spliced. Then go over all the ground cables and make sure they are tight. esp the neg coming off the battery. to the frame
it IS a ground wire and looks to be a part of the factory wiring harness...
my starter turns the engine over much faster since it's been disconnected..
how strange is that?
also my truck seems to run much better!!!!!!!
im lookin in the service manual but i faintly recall that ground splice point might be for the o2 sensors. this could explain why perhaps the truck runs better now. Ill keep looking and help find the answer
